WooCommerce PDF Invoices & Packing Slips
Guillermo
 Guillermo
Este plugin es el que genera la Factura o comprobante de los pedidos en woocommerce, pero cuando quiero generar una factura da un error fatal que no logro interpretar como solucionar, busque en varios foros y no hay nada especifico.
Podrán darme una mano con esto?
Fatal error: Call to a member function get_cellmap() on null
#0 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameDecorator/AbstractFrameDecorator.php(895): Dompdf\FrameReflower\TableCell->reflow(NULL)
#1 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameReflower/TableRow.php(52): Dompdf\FrameDecorator\AbstractFrameDecorator->reflow()
#2 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameDecorator/AbstractFrameDecorator.php(895): Dompdf\FrameReflower\TableRow->reflow(Object(Dompdf\FrameDecorator\Block))
#3 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameReflower/Block.php(845): Dompdf\FrameDecorator\AbstractFrameDecorator->reflow(Object(Dompdf\FrameDecorator\Block))
#4 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameDecorator/AbstractFrameDecorator.php(895): Dompdf\FrameReflower\Block->reflow(NULL)
#5 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameReflower/Page.php(141): Dompdf\FrameDecorator\AbstractFrameDecorator->reflow()
#6 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/FrameDecorator/AbstractFrameDecorator.php(895): Dompdf\FrameReflower\Page->reflow(NULL)
#7 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/vendor/dompdf/dompdf/src/Dompdf.php(847): Dompdf\FrameDecorator\AbstractFrameDecorator->reflow()
#8 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/includes/class-wcpdf-pdf-maker.php(53): Dompdf\Dompdf->render()
#9 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/includes/documents/abstract-wcpdf-order-document.php(629): WPO\WC\PDF_Invoices\PDF_Maker->output()
#10 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/includes/documents/abstract-wcpdf-order-document.php(664): WPO\WC\PDF_Invoices\Documents\Order_Document->get_pdf()
#11 /home/losclasi/public_html/keikrukweb.com.ar/wp-content/plugins/woocommerce-pdf-invoices-packing-slips/includes/class-wcpdf-main.php(337): WPO\WC\PDF_Invoices\Documents\Order_Document->output_pdf('inline')
#12 /home/losclasi/public_html/keikrukweb.com.ar/wp-includes/class-wp-hook.php(287): WPO\WC\PDF_Invoices\Main->generate_pdf_ajax('')
#13 /home/losclasi/public_html/keikrukweb.com.ar/wp-includes/class-wp-hook.php(311): WP_Hook->apply_filters('', Array)
#14 /home/losclasi/public_html/keikrukweb.com.ar/wp-includes/plugin.php(478): WP_Hook->do_action(Array)
#15 /home/losclasi/public_html/keikrukweb.com.ar/wp-admin/admin-ajax.php(175): do_action('wp_ajax_generat...')
#16 {main}
Adjunto imagen del -fatal error- que tira.
Muchas Gracias!
FATAL ERROR
Respondido : 24/05/2020 12:01 am
Hola Guillermo,
¿Puedes indicarnos cual es el dominio para tu consulta? de esta forma podemos verificar con mayor detalles.
De manera genera haz realizado algún cambio en tu sitio web de forma reciente?, como por ejemplo actualizado el plugin
Prueba desactivan el plugin, luego Eliminalo e instalalo nuevamente.
Verifica si aun te muestra el error al intentar imprimir la factura
Respondido : 24/05/2020 1:22 am
Guillermo
 Guillermo
Hola Karen, gracias por tu respuesta. El dominio es www.keikrukweb.com.ar
Ya probé desinstalar el plugin, borrrarlo y volverlo a instalar y sigue con el mismo error.
Gracias,
Slds,
Respondido : 24/05/2020 2:52 pm
Tal vez esta generando conflicto con algún otro plugin, prueba ir desactivando otros plugins y verifica si te causa conflicto con algún otro.
Respondido : 24/05/2020 3:55 pm
Aida
 Aida
Hola, he estado viendo un tutorial en el que explica que con el plugin Woocommerce PDF Invoices puedes descargarte un listado pdf para poder reunir todas las facturas y presentarlas en el trimestre.
Sin embargo, en el mio no aparece la opción "listados" . Me aparecen las siguientes pestañas : Genera/Documentos/Estados
y debería incluir una más llamada /listados/.
¿Me podéis indicar el motivo ? Gracias de antemano
Respondido : 05/10/2020 7:13 pm
Hola Aida,
Veo que ingresaste el nombre como Woocommerce PDF Invoices, si esto es correcto el complemento que haces referencia es otro distinto al comentado en este tema, puedes enviarnos cual es el nombre exacto del complemento que estas usando? adicional a esto la url de la que estas haciendo la consulta.
También crea un nuevo tema, de esta forma podemos darle seguimiento al mismo de una mejor manera.
Respondido : 05/10/2020 7:25 pm
Aida
 Aida
@argenis
es la primera vez en el foro y no se generar un nuevo tema, estuve buscando y no encontré la forma.
WooCommerce PDF Invoices & Packing Slips es el nombre del plugin que tengo instalado.
Gracias por echarme una mano.
Respondido : 06/10/2020 6:31 pm
Hola Aida,
Para abrir un tema en foro desde la opción foros donde indica Nuevo tema, también puedes seguir la siguiente guía -> https://guias.webempresa.com/preguntas-frecuentes/crear-una-consulta-ticket-foro/#como-realizo-una-consulta-en-el-foro
Screenshot
Ya que cada consulta es diferente al abrir una nuevo tema podemos ayudarte con mayor detalle sobre el problema que puedes presentar, adicional cuando abras el tema si es posible indícanos cual es la URL del sitio web donde presentas el problema con WooCommerce PDF Invoices & Packing Slips de esta forma podremos verificar exactamente que podría esta ocurriendo.
Respondido : 06/10/2020 7:06 pm
