Problema de Suhosin al instalar Ninjacontent
Alejandro
 Alejandro
Hola, estoy instalando el componente Ninjacontent para Joomla 1.5, en Teline IV y el sistema me dice que tengo que hacer unas modificaciones en el php.ini si se está utilizando suhosin. Lo que no interpreto es si se refiere a un php.ini del sistema en que está alojada la web, o se refiere a mi instalación en el phpadmin, o a algún módulo de joomla
¿podeis aclararme esto? Copio a continuación información adicional de error a la cual me reenvia el error.
Known Issues
Server running suhosin patch
Nooku Framework has problems with the Suhosin patch.
[error] [client 192.168.3.2] ALERT - Include filename
('tmpl:///var/www/joomla/components/com_foo/views/people/tmpl/default.php')
is an URL that is not allowed (attacker '192.168.3.2',
file '/var/www/joomla/plugins/system/koowa/view/abstract.php', line 418)
To fix this add the following to your php.ini file if you are using suhosin :
suhosin.executor.include.whitelist = tmpl://, file://
Remember that you likely need to add this to a php.ini file in your joomla root folder, and your /administrator/ folder.
And some .ini users might need to also add session.save_path = /tmp.
If the user can't use .ini configuration files, here's how to do it by .htaccess
php_value suhosin.executor.include.whitelist tmpl://, file://
For more info on the discussion : http://groups.google.com/group/nooku-framework/browse_frm/thread/10d526547d12e541/cab8643fb63c379a
Issues with PHP versions
PHP 5.2.5. : Bug in get_class_methods prevents KObject getMethods from working correctly. See : http://bugs.php.net/43483
This issue was also reported for PHP 5.2.4 : see http://groups.google.com/group/nooku-framework/browse_thread/thread/cba65e75ce04d857/0a3a7c5ad1d62762#0a3a7c5ad1d62762
This issue was solved in revision:2648
URL del sitio: http://www.mecuidomucho.com
Respondido : 11/05/2012 1:15 pm
Miguel Tuyaré
 Miguel Tuyaré
Hola Alejandro:
Suhosin es un sistema de protección muy eficiente que se utiliza a nivel servidor.
Para ver este tema, envía un ticket de soporte.
Respondido : 11/05/2012 1:42 pm
