Elementor se queda cargando
Pablo Ramon
 Pablo Ramon
Cuando intento editar mi página web, elementor se queda en la pantalla de carga. He probado con eliminar los plugins y volver a instalarlos y no ha funcionado.
El registro de errores PHP me pone esto:
[17-Jan-2024 11:57:49 UTC] PHP Fatal error: Uncaught Error: Call to a member function enqueue_styles() on null in /home2/hosting148797eu/public_html/pvaliente.com/wp-content/plugins/header-footer-elementor/inc/class-header-footer-elementor.php:385
Stack trace:
#0 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/class-wp-hook.php(324): Header_Footer_Elementor->enqueue_scripts('')
#1 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array)
#2 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/plugin.php(517): WP_Hook->do_action(Array)
#3 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/script-loader.php(2262): do_action('wp_enqueue_scri...')
#4 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/class-wp-customize-manager.php(457): wp_enqueue_scripts()
#5 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/class-wp-customize-manager.php(556): WP_Customize_Manager->wp_die(0, 'Non-existent ch...')
#6 /home2/hosting148797eu/public_html/pvalien in /home2/hosting148797eu/public_html/pvaliente.com/wp-content/plugins/header-footer-elementor/inc/class-header-footer-elementor.php on line 385
[17-Jan-2024 12:04:16 UTC] PHP Fatal error: Uncaught Error: Class 'Elementor\Core\Experiments\Manager' not found in /home2/hosting148797eu/public_html/pvaliente.com/wp-content/plugins/elementor/includes/plugin.php:706
Stack trace:
#0 /home2/hosting148797eu/public_html/pvaliente.com/wp-content/plugins/elementor/includes/plugin.php(647): Elementor\Plugin->init_components()
#1 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/class-wp-hook.php(324): Elementor\Plugin->init('')
#2 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array)
#3 /home2/hosting148797eu/public_html/pvaliente.com/wp-includes/plugin.php(517): WP_Hook->do_action(Array)
#4 /home2/hosting148797eu/public_html/pvaliente.com/wp-settings.php(643): do_action('init')
#5 /home2/hosting148797eu/public_html/pvaliente.com/wp-config.php(103): require_once('/home2/hosting1...')
#6 /home2/hosting148797eu/public_html/pvaliente.com/wp-load.php(50): require_once('/home2/hosting1...')
#7 /home2/hosting148797eu/public_html/pvalien in /home2/hosting148797eu/public_html/pvaliente.com/wp-content/plugins/elementor/includes/plugin.php on line 706
[17-Jan-2024 12:07:19 UTC] Error de evento de reprogramación de cron para el gancho: wpo_reset_webp_conversion_test_result. Código de error: invalid_schedule. Mensaje de error: El evento programado no existe.. Datos: {"schedule":"wpo_daily","args":[],"interval":86400}
Respondido : 17/01/2024 6:19 pm
Hola Pablo,
Es posible que este comportamiento lo esté añadiendo un conflicto con otro plugin, para verificarlo activa el modo seguro en Elementor y comprueba luego si carga de forma correcta.
Para activar el modo seguro debes accede a Elementor -> Herramientas -> General y activa la opción donde indica modo seguro
Herramientas Mi sitio WPWooCommerce — WordPress
Adicional a esto veo un error fatal que se generó con el plugin de Pro Elements
[15-Jan-2024 02:41:29 UTC] PHP Fatal error: Uncaught Error: Call to a member function update_meta() on null in /home2/hosting148797eu/public_html/pvaliente.com/wp-content/plugins/pro-elements/modules/theme-builder/classes/conditions-manager.php:312
Revisa desactivar este plugin y comprueba como va todo
Respondido : 17/01/2024 6:50 pm
Pablo Ramon
 Pablo Ramon
Hola @karen, gracias por tu respuesta.
He activado el modo seguro y he desactivado el plugin de pro elements, pero sigo con el mismo problema. No pasa de la pantalla de carga cuando intento editar una página.
Respondido : 18/01/2024 12:30 pm
Hola Pablo.
Prueba una cosa:
.- Desactiva el plugin Elementor Header & Footer Builder
.- Accede ajustes -> enlaces permanentes y sin realizar ningún cambio pulsa en el boton de guardar
Revisa si mejora la carga y nos comentas.
Si no se solucionara desactiva CloudFlare y lo pruebas, hay problemas conocidos entre CloudFlare y elementor.
Respondido : 18/01/2024 12:59 pm
Pablo Ramon
 Pablo Ramon
Hola Pepe, he realizado lo que me has dicho pero sigue sin pasar de la pantalla de carga.
Respondido : 18/01/2024 2:42 pm
Hola Pablo.
Desactivaste CloudFlare ?
Veo que sigue cargando desde CloudFlare:
pvaliente.com apunta según google a:
amanda.ns.cloudflare.com.
jack.ns.cloudflare.com.
Intenta limpiar la cache de CloutFlare:
-> https://www.webempresa.com/blog/como-limpiar-cache-de-cloudflare.html
Si después de limpiarla no se soluciona desactiva cloudflare y lo revisas
Respondido : 18/01/2024 3:19 pm
Pablo Ramon
 Pablo Ramon
Hola Pepe
Intente borrar el cache y no funcionó, ahora desactive el cloudflare y sigue igual
Respondido : 18/01/2024 3:52 pm
Hola Pablo,
Aun veo que siguen cargando con cloudflare, es posible esto demore un tiempo en cambiarse. Prueba borrar nuevamente la caché desde cloudflare y comprueba como va todo.
Una vez compruebes todo este modificado revisa activa el plugin de pro elements y revisa si no te genera ningún conflicto.
Respondido : 18/01/2024 4:22 pm
Pablo Ramon
 Pablo Ramon
Hola Karen
He desactivado cloudflare, también borre la cache, ahora active el plugin de pro elements de nuevo y sigue igual. Los test/comprobaciones de web empresa no detectan ningún conflicto. Pero sigo sin poder entrar a editar las páginas.
Respondido : 18/01/2024 4:41 pm
Hola Pablo,
El análisis me indica que aún está apuntando a cloudlfare, esto puede demorar en cambiar un poco mientras se propaguen los DNS
Espera un par de horas y revisa nuevamente como va todo, envíanos capturas sobre lo que te muestre en ese momento para revisar con mayor detalle lo que sucede.
Respondido : 18/01/2024 4:45 pm
