problema con la plantilla
Página 2 / 2
Santi
 Santi
Buenos días.
Tengo un problema con la plantila. No se cual es el problema pero no puedo subir ningún plugin desde wordpress y me da error al activar alguno. la web es www.akhealthbeuty.com
He escrito un ticket y me ha remistido al foro. esto me han escrito.
[21-Aug-2014 07:03:22 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[21-Aug-2014 07:03:23 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[26-Aug-2014 09:00:19 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[26-Aug-2014 09:00:20 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[26-Aug-2014 09:00:49 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[26-Aug-2014 09:00:50 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[26-Aug-2014 09:01:56 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
[26-Aug-2014 09:01:57 UTC] PHP Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
Respondido : 27/08/2014 10:48 am
Santi
 Santi
Hola;
No me mareais, al contrario. No he probao, pero del tiket me han deicho que pruebe a cambiar de tema e instalar completamente todo por unos plugins que van asociados y me han dado algún tipo de error.
Lo haré y te cmentaré como va. gracias
Respondido : 13/09/2014 1:06 am
Hola Santi,
Efectivamente el tema de pago que usas parece tener algún problema con WooCommerce y esto genera problemas colaterales con la instalación de otros plugins y errores como:
This theme requires the following plugins: CrunchPress Book Appointment, CrunchPress Post Types & Options and WooCommerce.Begin installing plugins | Dismiss this notice
Es recomendable que contactes con el desarrollador del tema adquirido para que te de indicaciones al respecto o en todo caso de facilite una actualización del mismo, que además sea compatible con WordPress 4.0.
Respondido : 13/09/2014 3:32 am
Santi
 Santi
Buenos días;
El servicio técnico de la plantilla, no me hace caso en absoluto. Hace ya más de tres días que no me contesta. En principio, he pensado en borrar el tema y volver a instalarlo desde ftp. El problema es que tengo miedo a perder todo el trabajo realizado. ¿Se podría utilizar algunos de los back up, de las copias de seguridad que he hecho? o por el contrario eso haría que se volviese a quedar defectuoso?.
Un consejo gracias.
Respondido : 13/09/2014 11:23 am
Santi
 Santi
Hola He desinstalado la plantilla y la he vuelto a instalar y me genera este error en algunos puntos de los plugins. Nadie me contesta en el soporte de la empresa desde hace días.
1-"El plugin no tiene una cabecera valida"
2-Fatal error: Cannot redeclare add_post_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/blog/post-option.php:106) in /home/akhealth/public_html/wp-content/plugins/crunchpress-blog-options/post-option.php on line 108
3-Fatal error: Cannot redeclare add_page_option() (previously declared in /home/akhealth/public_html/wp-content/themes/beautyfit/framework/options/page/page-option.php:1126) in /home/akhealth/public_html/wp-content/plugins/crunchpress-page-options/page-option.php on line 1535
Respondido : 13/09/2014 12:45 pm
Hola Santi
Es posible que la plantilla que usas tenga dependencias de algún tipo busca en los plugins si hay algo relacionado con tu plantilla, usulamente un framework
Has probado los instaladores de tu plantilla en otro sitio web wordpress?
Luego una opción final sería que restaures una copia de seguridad de tu sitio antes de que hayas tenido los problemas
Respondido : 14/09/2014 7:05 pm
Santi
 Santi
No he probado en otro sirio wordpress. No tengo tampoco, que yo sepa ninguna caopia de seguridad de antes de los problemas, ya que ha dado problemas desde el primer momento, addemás la web estaba casi sin empezar cuando tuve problemas con el editor de texto.
La platilla viene con unos plugins recomendados pero que se han debido dañar, y no me deja activarlos.
Respondido : 14/09/2014 7:56 pm
Santi
 Santi
MUCHAS GRACIAS por l a respuesta. He realizado un camio de la base de datos y el salvado cosas, aunque la plantilla sigue dándome problemas. De hecho tengo un problema, ya que la cabecera tiene en la página de inicio unos problemas ya que no puedo quitar el carrito de woo commerce ni nada de lo que aparece.
Adjunto foto . Es la parte superior. ¿ Cómo puedo eliminarlo?
Respondido : 15/09/2014 2:20 am
Santi
 Santi
Además tengo un problema , ya que no funciona la home principla, se han deshabilitado casi todas las funciones cuando he empezado a activar WPML
No funciona ninguno de los efectos de la página principal. No hay slider, ni nada.
nosé
Stephan me marca esto.
Revisión de ficheros que ocupan más espacio en su cuenta:
Hemos encontrado los siguientes ficheros que ocupan más de 10 MB, si tiene problemas de espacio es posible que quiera bajarlos a su equipo y eliminarlos del servidor:
127 MB en el fichero /home/akhealth/application_backups/app_akhealth-cp53-wordpresstemporal-com_Mi-Blog-CMS_2014-08-07_08-05-32.tar.gz
127 MB en el fichero /home/akhealth/application_backups/app_akhealth-cp53-wordpresstemporal-com_Mi-Blog-CMS_2014-08-07_06-41-50.tar.gz
Revisión Error fatal:
Vemos que hay logs de errores que podrian generar un error 500 en el servidor
[12-Sep-2014 16:06:52 Europe/Berlin] PHP Fatal error: require() [function.require]: Failed opening required '/home/akhealth/public_html/wp-includes/load.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/akhealth/public_html/wp-settings.php on line 21
[12-Sep-2014 16:08:53 Europe/Berlin] PHP Fatal error: require() [function.require]: Failed opening required '/home/akhealth/public_html/wp-includes/load.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/akhealth/public_html/wp-settings.php on line 21
[12-Sep-2014 19:27:37 Europe/Berlin] PHP Fatal error: Call to undefined function get_header() in /home/akhealth/public_html/wp-content/themes/beautyfit/index.php on line 5
[12-Sep-2014 19:28:30 Europe/Berlin] PHP Fatal error: Call to undefined function get_header() in /home/akhealth/public_html/wp-content/themes/beautyfit/index.php on line 5
[12-Sep-2014 19:28:52 Europe/Berlin] PHP Fatal error: Call to undefined function get_header() in /home/akhealth/public_html/wp-content/themes/beautyfit/index.php on line 5
[12-Sep-2014 21:18:04 Europe/Berlin] PHP Fatal error: Call to undefined function get_header() in /home/akhealth/public_html/wp-content/themes/beautyfit/index.php on line 5
[12-Sep-2014 21:19:06 Europe/Berlin] PHP Fatal error: Call to undefined function get_header() in /home/akhealth/public_html/wp-content/themes/beautyfit/index.php on line 5
[12-Sep-2014 21:19:28 Europe/Berlin] PHP Fatal error: Call to undefined function get_header() in /home/akhealth/public_html/wp-content/themes/beautyfit/index.php on line 5
Revisión Parse error:
Vemos que hay logs de errores del parser en el PHP, esto significa que hay errores de PHP
[11-Sep-2014 14:34:22 UTC] PHP Parse error: syntax error, unexpected $end in /home/akhealth/public_html/wp-content/plugins/widget-logic/widget_logic.php(286) : eval()'d code on line 1
Revisión Wordpress Instalados:
Vemos que tiene las siguientes instalaciones de WordPress:
- Akj Health&Beauty
Descripción: Ana Kristina Goitia-Jon Jaio
Dominios: akhealth-cp53.wordpresstemporal.com akjibiza.com www.akhealth-cp53.wordpresstemporal.com www.akhealthbeauty.com www.akjibiza.com
URL de sitio: http://akhealthbeauty.com (URL configurada en la BBDD de Wordpress, ha de ser una URL válida)
Directorio: /home/akhealth/public_html/
Versión: 4.0
Template: beautyfit
PHP Requerido: 5.2.4 o superior
Base de datos: akhealth_pw1
Prefijo: wp_
Usuario BBDD: akhealth_pw1
Host: localhost
Gzip: 0
Charset BBDD: utf8
Collate BBDD:
Directorio Temporal:
Upload path: /home/akhealth/public_html/wp-content/uploads
Upload Url Path:
Lenguaje: es_ES
Debug: define('WP_DEBUG', false);
Defines particulares en wp-config.php:
define('WP_CACHE', false); //Added by WP-Cache Manager
define( 'WPCACHEHOME', '/home/akhealth/public_html/wp-content/plugins/wp-super-cache/' ); //Added by WP-Cache Manager
* Listado de plugins Activos:
All In One SEO Pack -- 2.2.2 -- http://semperfiwebdesign.com
CodeStyling Localization -- 1.99.30 -- http://www.code-styling.de/english/development/wordpress-plugin-codestyling-localization-en
Cookie Law Info -- 1.2.1 -- http://wordpress.org/extend/plugins/cookie-law-info/description/
CrunchPress Appointment Booking -- 1.01 -- http://crunchpree.com/
CrunchPress Post Types Options -- 1.0 -- http://crunchpress.com/
InfiniteWP - Client -- 1.2.13 -- http://infinitewp.com/
NextGEN Gallery by Photocrati -- 2.0.66.27 -- http://www.nextgen-gallery.com
Regenerate Thumbnails -- 2.2.4 -- http://www.viper007bond.com/wordpress-plugins/regenerate-thumbnails/
WPML Multilingual CMS -- 2.7.1 -- http://wpml.org/
TinyMCE Advanced -- 4.0.2 -- http://www.laptoptips.ca/projects/tinymce-advanced/
Use Google Libraries -- 1.5.2 -- http://jasonpenney.net/wordpress-plugins/use-google-libraries/
WooCommerce -- 2.1.7 -- http://www.woothemes.com/woocommerce/
WPML String Translation -- 1.6.1 -- http://wpml.org/
XCloner -- 3.1.1 -- http://www.xcloner.com
Directorio de plugins /home/akhealth/public_html//wp-content/plugins:
/home/akhealth/public_html//wp-content/plugins/all-in-one-seo-pack
/home/akhealth/public_html//wp-content/plugins/better-wp-security
/home/akhealth/public_html//wp-content/plugins/codestyling-localization
/home/akhealth/public_html//wp-content/plugins/cookie-law-info
/home/akhealth/public_html//wp-content/plugins/crunchpress-appointment-booking-calendar
/home/akhealth/public_html//wp-content/plugins/crunchpress-post-types-options
/home/akhealth/public_html//wp-content/plugins/fancybox-for-wordpress
/home/akhealth/public_html//wp-content/plugins/filebrowser
/home/akhealth/public_html//wp-content/plugins/google-analytics-for-wordpress
/home/akhealth/public_html//wp-content/plugins/google-sitemap-generator
/home/akhealth/public_html//wp-content/plugins/iwp-client
/home/akhealth/public_html//wp-content/plugins/nextgen-gallery
/home/akhealth/public_html//wp-content/plugins/regenerate-thumbnails
/home/akhealth/public_html//wp-content/plugins/sitepress-multilingual-cms
/home/akhealth/public_html//wp-content/plugins/smpl-shortcodes
/home/akhealth/public_html//wp-content/plugins/tinymce-advanced
/home/akhealth/public_html//wp-content/plugins/use-google-libraries
/home/akhealth/public_html//wp-content/plugins/widget-logic
/home/akhealth/public_html//wp-content/plugins/woocommerce
/home/akhealth/public_html//wp-content/plugins/wp-super-cache
/home/akhealth/public_html//wp-content/plugins/wpml-string-translation
/home/akhealth/public_html//wp-content/plugins/xcloner-backup-and-restore
Vemos que tiene más de 10 plugins instalados en su Wordpress, le recomendamos desactivar los que no utilice y finalmente desinstalarlos cuando haya verificado que no los necesita.
Conseguirá aumentar el rendimiento de su Wordpress y mejorará la experiencia de los usuarios que visiten su web.
Atención!! Vemos que no tiene habilitadas las reglas de protección de ataques por fuerza bruta a su Wordpress y tampoco vemos que tenga protegido su wp-login.php vía .htaccess. Tendría que proteger su fichero wp-login.php añadiendo el código adecuado al fichero /home/akhealth/public_html/.htaccess.
Puede ser de utilidad el siguiente artículo de nuestro blog: https://www.webempresa.com/blog/item/1391-modifica-el-login-de-wordpress-para-evitar-ataques-de-fuerza-bruta.html
Revisión
Restauraciones desde cPremote
Se han encontrado estas restauraciones realizadas desde cPremote en su cuenta:
Sat, 13 Sep 2014 15:00:02 +0200 : Restoring public_html fodler for the user akhealth from daily backup
Respondido : 15/09/2014 3:16 am
Hola Santi,
En la revisión se muestran errores de PHP, pero no son de fecha actual. El tema es que la plantilla te está dando problemas desde el principio, ahora es posible que tenga incompatibilidades con WPML.
Creo que es importante tomes una decisión:
- O contactar con los desarrolladores del tema instalado, para que resuelvan los errores del mismo
- O utilizar otro tema.
Respondido : 15/09/2014 10:34 am
Página 2 / 2
