[Resuelto] Problemas de redirección con gtranslate
Lucia
 Lucia
Hola, tengo instalado el  plugin de gtranslate pro en mi web, el problema es el siguiente. Cuando pongo https://kalena.es/en sin barra al final, me funciona, pero me redirecciona a una dirección muy rara ( https://kalena.es/wp-content/plugins/gtranslate/url_addon/gtranslate.php?glang=en&gurl=) si lo pongo con barra al final https://kalena.es/en/ con la barra al final me funciona perfectamente.
Los de soporte del plugin me dicen que eso es que falta unasreglas de redirección en el ngix.config,en concreto estas:
rewrite ^/(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)/(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)/(.*)$ /$1/$3 permanent; rewrite ^/(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)/(.*)$ /wp-content/plugins/gtranslate/url_addon/gtranslate.php?glang=$1&gurl=$2 last; rewrite ^/(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)$ /$1/ permanent;
Vuestro soporte me ha dicho que pregunte aquí. que se puede hacer esto desde el htaccess, pero yo no se cómo. ¿podéis ayudarme con ésto?.
Muchas gracias desde ya.
Respondido : 01/03/2022 5:27 pm
Hola Lucia,
Puedes agregar esto en tu archivo htaccess, para ello ingresas a:
Cpanel > Administrador de archivos > Public_html > Dominio > Archivo .htaccess
Al abrir dicho archivo colocas este codigo que nos compartes antes de la etiqueta de cierre.
Sin embargo, contacta con soporte y que te faciliten el código que debes agregar a tu htaccess para que esto funcione de forma correcta, ya que el que nos compartes parece no estar completo.
Respondido : 01/03/2022 5:56 pm
Lucia
 Lucia
hola @argenis , ahora mismo el htacces está así
### BEGIN GTranslate config ###
RewriteRule ^(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)/(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)/(.*)$ /$1/$3 [R=301,L]
RewriteRule ^(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)/(.*)$ /wp-content/plugins/gtranslate/url_addon/gtranslate.php?glang=$1&gurl=$2 [L,QSA]
RewriteRule ^(af|sq|am|ar|hy|az|eu|be|bn|bs|bg|ca|ceb|ny|zh-CN|zh-TW|co|hr|cs|da|nl|en|eo|et|tl|fi|fr|fy|gl|ka|de|el|gu|ht|ha|haw|iw|hi|hmn|hu|is|ig|id|ga|it|ja|jw|kn|kk|km|ko|ku|ky|lo|la|lv|lt|lb|mk|mg|ms|ml|mt|mi|mr|mn|my|ne|no|ps|fa|pl|pt|pa|ro|ru|sm|gd|sr|st|sn|sd|si|sk|sl|so|es|su|sw|sv|tg|ta|te|th|tr|uk|ur|uz|vi|cy|xh|yi|yo|zu)$ /$1/ [R=301,L]
### END GTranslate config ###
<FilesMatch ".(php4|php5|php3|php2|php|phtml)$">
SetHandler application/x-lsphp74
</FilesMatch>
# BEGIN rlrssslReallySimpleSSL rsssl_version[4.0.15]
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP:X-Forwarded-Proto} !https
RewriteCond %{REQUEST_URI} !^/\.well-known/acme-challenge/
RewriteRule ^(.*)$ https://%{HTTP_HOST}/$1 [R=301,L]
</IfModule>
# END rlrssslReallySimpleSSL
# BEGIN WordPress
# Las directivas (líneas) entre «BEGIN WordPress» y «END WordPress» son
# generadas dinámicamente y solo deberían ser modificadas mediante filtros de WordPress.
# Cualquier cambio en las directivas que hay entre esos marcadores serán sobrescritas.
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
RewriteEngine on
</IfModule>
Pero sigue sin funcionar, ¿Hay algo mal escrito? .
En cuanto a soporte, como te dije, en el de GT me mandaron ese código y me dijeron que como era un servidor nginx no podían acceder al .conf y que se lo preguntara al de mi hosting y de ahí me dijeron que en el .conf no se podía tocar que lo hiciera en el htacces y que os preguntara aquí en el foro como se hacía...
Respondido : 02/03/2022 8:59 am
Hola Lucia.
Prueba a eliminar todo el bloque de Gtranslate que tienes en el archivo htaccess:
-> https://wordpress.org/support/topic/the-transition-to-the-new-language-page-does-not-work/
Antes de eliminar descarga una copia para tener el original.
Respondido : 02/03/2022 9:52 am
Lucia
 Lucia
Hola @pepesoler , al eliminarlo funciona perfectamente. Muchas gracias
El caso es que tengo copia del htcaccess de ayer y ese código no aparecía y tp funcionaba, no entiendo  nada pero ya funciona.
Muchas gracias a los dos por vuestras respuestas y sobre todo por la rapidez de las mismas. Enhorabuena!
Esta publicación ha sido modificada el hace 3 años por Lucia
Respondido : 02/03/2022 10:14 am
Hola Lucia.
Genial !!! Me alegra que lo solucionaras.
Cerramos el tema.
Respondido : 02/03/2022 10:35 am
