Mautic no recoge ac...
Mautic no recoge actividad
17 Visitas
Respuestas: 2
Hola. Creo que el error que estoy detectando viene desde que creé un nuevo campo personalizado en la base de datos. Detecté el error porque no registraba los nuevos "Contactos" que se envían desde un formulario web. Al eliminar el nuevo campo personalizado que creé, Mautic ya incorpora a los nuevos "Contactos", pero haciendo pruebas veo que no registra las consultas a los "Activos". Adjunto primer y últimos registros de errores.
[2024-10-28 00:34:28] mautic.WARNING: PHP Warning - Trying to access array offset on value of type bool - in file /home/mtc210351eu/public_html/app/bundles/PageBundle/Entity/HitRepository.php - at line 267 [] {"hostname":"cp7256.webempresa.eu","pid":588438}
[2024-10-28 08:54:03] mautic.WARNING: PHP Warning - Trying to access array offset on value of type bool - in file /home/mtc210351eu/public_html/app/bundles/PageBundle/Entity/HitRepository.php - at line 267 [] {"hostname":"cp7256.webempresa.eu","pid":1818777}
[2024-10-28 09:13:27] mautic.CRITICAL: Uncaught PHP Exception Doctrine\DBAL\Exception\DeadlockException: "An exception occurred while executing 'UPDATE leads SET date_modified = ? WHERE id = ?' with params ["2024-10-28 09:13:27", "368"]: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction" at /home/mtc210351eu/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php line 51 {"exception":"[object] (Doctrine\\DBAL\\Exception\\DeadlockException(code: 0): An exception occurred while executing 'UPDATE leads SET date_modified = ? WHERE id = ?' with params [\"2024-10-28 09:13:27\", \"368\"]:\n\nSQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction at /home/mtc210351eu/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php:51, Doctrine\\DBAL\\Driver\\PDO\\Exception(code: 40001): SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction at /home/mtc210351eu/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDO/Exception.php:18, PDOException(code: 40001): SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction at /home/mtc210351eu/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:117)"} {"hostname":"cp7256.webempresa.eu","pid":1854467}
Respondido : 28/10/2024 9:38 am
Respuestas: 19355
Hola Felix,
En este caso, ya que entiendo realizaste ciertas medicaciones a la base de datos te recomiendo abras un ticket a soporte para que revisen completamente lo que sucede y comprueben todo está funcionando de forma correcta, ten en cuenta que no podemos acceder a tu cuenta en mautic y revisarlo de forma detallada.
Respondido : 28/10/2024 4:13 pm
Respuestas: 2
@karen Gracias hago lo que me propones. Un saludo.
Respondido : 29/10/2024 5:29 am
Respuestas: 42146
Hola Felix.
Ok, dejo el hilo abierto por si necesitas retomarlo.
Respondido : 29/10/2024 12:57 pm
