cificado el cache d...
cificado el cache deespecificar cache del navegador
Juan David
 Juan David
hola buenas tardes
me sale que no tengo especificado el cache del navegador de las imagenes .jpg el error me sale en pingdom, gtmetrix y google page speed
y ya tengo asi mi codigo .htacces
Spoiler
#RewriteEngine On
#RewriteCond %{ENV:HTTPS} !on [NC]
#RewriteCond %{QUERY_STRING} !wc-api [NC]
#RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L,NE]
ExpiresActive On
ExpiresByType image/gif "access plus 1 month"
ExpiresByType image/jpeg "access plus 1 month"
ExpiresByType image/jpg "access plus 1 month"
ExpiresByType image/png "access plus 1 month"
ExpiresByType text/css "access plus 1 week"
ExpiresByType text/javascript "access plus 1 week"
ExpiresByType application/javascript "access plus 1 week"
ExpiresByType application/x-javascript "access plus 1 week"
ExpiresByType image/x-icon "access plus 1 year"
ExpiresByType image/svg+xml "access plus 1 year"
ExpiresByType image/vnd.microsoft.icon "access plus 1 year"
ExpiresByType application/font-woff "access plus 1 year"
ExpiresByType application/x-font-woff "access plus 1 year"
ExpiresByType application/vnd.ms-fontobject "access plus 1 year"
ExpiresByType font/opentype "access plus 1 year"
ExpiresByType font/ttf "access plus 1 year"
ExpiresByType font/otf "access plus 1 year"
ExpiresByType application/x-font-ttf "access plus 1 year"
ExpiresByType application/x-font-otf "access plus 1 year"
# Habilitar compresion para los siguientes tipos de archivo.
AddOutputFilterByType
DEFLATE
Application / javascript
Text / css
Text / html
Text / javascript
Texto sin formato
Text / xml
# compress text, HTML, JavaScript, CSS, and XML
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/xml
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/x-javascript
# remove browser bugs
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4.0[678] no-gzip
BrowserMatch bMSIE !no-gzip !gzip-only-text/html
Header append Vary User-Agent
# ~~start~~ Do not remove this comment, Prestashop will keep automatically the code outside this comment when .htaccess will be generated again
# .htaccess automaticaly generated by PrestaShop e-commerce open-source solution
# http://www.prestashop.com - http://www.prestashop.com/forums
SetEnv HTTP_MOD_REWRITE On
RewriteEngine on
#Domain: accesoriosrouse.com
RewriteRule . - [E=REWRITEBASE:/]
RewriteRule ^api$ api/ [L]
RewriteRule ^api/(.*)$ %{ENV:REWRITEBASE}webservice/dispatcher.php?url=$1 [QSA,L]
# Images
RewriteRule ^([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$1$2$3.jpg [L]
RewriteRule ^([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$1$2$3$4.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$1$2$3$4$5.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$1$2$3$4$5$6.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$7/$8/$1$2$3$4$5$6$7$8$9$10.jpg [L]
RewriteRule ^c/([0-9]+)(-[.*_a-zA-Z0-9-]*)(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/c/$1$2$3.jpg [L]
RewriteRule ^c/([a-zA-Z_-]+)(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/c/$1$2.jpg [L]
# AlphaImageLoader for IE and fancybox
RewriteRule ^images_ie/?([^/]+).(jpe?g|png|gif)$ js/jquery/plugins/fancybox/images/$1.$2 [L]
# Dispatcher
RewriteCond %{REQUEST_FILENAME} -s [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
RewriteRule ^.*$ %{ENV:REWRITEBASE}index.php [NC,L]
AddType application/vnd.ms-fontobject .eot
AddType font/ttf .ttf
AddType font/otf .otf
AddType font/woff2 .woff2
AddType application/x-font-woff .woff
Header set Access-Control-Allow-Origin "*"
ExpiresActive On
Header unset Etag
FileETag none
AddOutputFilterByType DEFLATE text/html text/css text/javascript application/javascript application/x-javascript font/ttf application/x-font-ttf font/otf application/x-font-otf font/opentype image/svg+xml
#If rewrite mod isn't enabled
ErrorDocument 404 /index.php?controller=404
# ~~end~~ Do not remove this comment, Prestashop will keep automatically the code outside this comment when .htaccess will be generated again
# BEGIN WordPress
#RewriteEngine On
#RewriteBase /blog/
#RewriteRule ^index.php$ - [L]
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteRule . /blog/index.php [L]
# END WordPress
ExpiresActive On
Header unset Etag
FileETag none
que puede estar mal ?
gracias
Respondido : 25/09/2017 12:13 am
Hola Juan David,
Puedes añadir el siguiente código de caducidad de tiempo de caché imágenes de PrestaShop en tu archivo .htaccess:
FileETag INode MTime Size
Insertalo antes del bloque de tu archivo .htaccess:
Respondido : 25/09/2017 1:16 am
Juan David
 Juan David
seguro que este es el codigo
ya puse el codigo de arriba que me das y sigue igual
gracias
Respondido : 25/09/2017 2:28 am
Hola Juan David,
Discúlpame, te indico el correcto:
	ExpiresActive On
Respondido : 25/09/2017 3:03 am
Juan David
 Juan David
ya lo puse sigue apareciendo
Respondido : 25/09/2017 3:39 am
Hola Juan David,
Revisa este hilo del Foro donde explico donde exactamente y como deben insertarse estos códigos:
https://www.webempresa.com/foro/42-Administraci%C3%B3n-PrestaShop/155254-Establecer-fecha-de-caducidad-en-imagenes-y-carga-asincr%C3%B3nica-de-analitics-en-htaccess.html
Ten en cuenta que depende de en que parte de .htaccess lo insertes.
No olvides limpiar la caché de PrestaShop antes de verificar de nuevo tu página en las diferentes herramientas como PageSpeed, etc.
Respondido : 25/09/2017 3:43 am
