El esquema data-voc...
[Cerrado] El esquema data-vocabulary.org está obsoleto
Página 2 / 2
MARIA DEL MAR
 MARIA DEL MAR
hola como puedo corregir este problema que me dice
Google Search Console
Respondido : 22/02/2020 8:43 pm
Veo que hay un módulo gratuito para el breadcrumbs que te corrige este problema, revisa:
https://www.prestashop.com/forums/topic/1013320-free-module-prestashop-16-modern-breadcrumb-data-vocabularyorg-schema-fix/
Respondido : 02/03/2020 4:45 pm
MARIA DEL MAR
 MARIA DEL MAR
@jmarreros
un modulo no es daba errores
ya hay que modificar el codigo breadcrumb.tpl por este
<! - Pan rallado ->
{if isset ($ smarty.capture.path)} {asignar var = 'ruta' valor = $ smarty.capture.path} {/ if}
{if! empty ($ ruta)}
{$ matchCount = preg_match_all ( '/ <a href = .+? "(.+?)" [^> ] *> ([^ <] *) <\ / a> /', $ trayectoria, $ coincidencias)}
{$ breadcrumbs = []}
{para $ i = 0; $ i <$ matchCount; $ i ++}
{$ breadcrumbs [] = ['url' => $ coincide [1] [$ i], 'título' => $ coincide [2] [$ i]]}
{/para}
{$ match = preg_match ('/> ([^ <] +) (?: <\ / \\ w +> s *)? $ /', $ ruta, $ coincidencias)}
{if! empty ($ coincide [1])}
{$ breadcrumbs [] = ['url' => '', 'title' => $ coincide [1]]}
{elseif! $ match &&! $ matchCount}
{$ breadcrumbs [] = ['url' => '', 'title' => $ ruta]}
{/Si}
{/Si}
<div class = "clearfix" > <ol class = "breadcrumb" itemscope itemtype = "http://schema.org/BreadcrumbList" > <li itemprop = "itemListElement" itemscope itemtype = "http://schema.org/ListItem " > <a class = " home " href = " {if isset ($ force_ssl) && $ force_ssl} {$ base_dir_ssl} {else} {$ base_dir} {/ if} " title = " {ls = 'Volver al inicio' } " itemprop = " item "> <i clase =
				 "icon-home" > </i> </a> <meta itemprop = "name" content = "{ls = 'Home'}" /> <meta itemprop = "position" content = "1" /> </ li>
{if! empty ($ breadcrumbs)}
{foreach from = $ breadcrumbs item = breadcrumb name = migas}
		<li itemprop = "itemListElement" itemscope itemtype = "http://schema.org/ListItem" >
{if! empty ($ breadcrumb.url)}
			<a href = "{$breadcrumb.url}" itemprop = "item" title = "{$breadcrumb.title}"> <span itemprop = "nombre" > {$ breadcrumb.title} </ span> </a>
{más}
			<span itemprop = "name" > {$ breadcrumb.title} </span>
{/Si}
			<meta itemprop = "position" content = "{($ smarty.foreach.crumbs.iteration | intval + 1)}" /> </li>
{/para cada}
{/Si}
	</ol> </div>
{if isset ($ smarty.get.search_query) && isset ($ smarty.get.results) && $ smarty.get.results> 1 && isset ($ smarty.server.HTTP_REFERER)}
<div class = "pull-right" > <strong>
		{capture} {if isset ($ smarty.get.HTTP_REFERER) && $ smarty.get.HTTP_REFERER} {$ smarty.get.HTTP_REFERER} {elseif isset ($ smarty.server.HTTP_REFERER) && $ smarty.server.HTTP_REFERER {{ $ smarty.server.HTTP_REFERER} {/ if} {/ capture}
		<a href = "{$ smarty.capture.default | escape: 'html': 'UTF-8' | secureReferrer | regex_replace: '/ [\? | &] content_only = 1 /': ''}" name = " Atrás " > <i class = " icon-chevron-left left " > </i> {ls = 'Volver a los resultados de búsqueda para"% s "(% d otros resultados)' sprintf = [$ smarty.get.search_query, $ smarty.get.results]}
		 </a> </strong> </div>
{/Si}
<! - / Pan rallado ->
pero ahora no me fuciona el menu horizontal en el telefono
Respondido : 04/03/2020 10:15 am
Hola Javier.
Por favor realiza la consulta con tu usuario, es decir no sigas una consulta de un usuario.
Más que nada porque al seguir la consulta de otro cliente nosotros no podemos hacer las pruebas necesarias que necesitamos en tu cuenta y esto se podría hacer eterno solo pidiendo información que de la otra manera la podemos obtener nosotros.
Respondido : 04/03/2020 10:24 am
MARIA DEL MAR
 MARIA DEL MAR
no se a que se refiere la pregunta sobre
la realice yo asi que no se como quien quiere que le responda
Respondido : 04/03/2020 12:52 pm
Hola Javier.
Por favor abre un nuevo con tu consulta y lo revisamos.
Al seguir con la consulta de otro usuario, no podemos realizar las pruebas que necesitamos para poder darte una solución.
un saludo
Respondido : 04/03/2020 2:28 pm
Lazaro Valente
 Lazaro Valente
pues mi tema es
AdBooster
y ese archivo no lo encuentro en ningún lugar.. ayuda
Respondido : 10/10/2020 6:36 am
Bulmaro
 Bulmaro
Hola Javier,
Por favor, abre un nuevo hilo en el foro donde expongas por completo tu caso indicándonos el sitio web afectado, etc. Así evitamos que se mezclen casos aunque parecidos en realidad son distintos.
Respondido : 10/10/2020 3:16 pm
Reyes
 Reyes
@pepesoler buenos días Pepe, verás tengo el mismo problema que el otro usuario, me salen 690 El esquema data-vocabulary.org está obsoleto.
pero en mi plantilla de Howes no encuentro el modo de solucionarlo porque no veo el archivo breadcrumb.tpl. si ese el archivo donde tengo que modificar el código.
Respondido : 29/04/2021 9:20 am
Hola Reyes, Buenos Días.
Por favor abre un nuevo tema, este ya es antiguo y con diferentes usuarios ademas no podemos revisar tu instalación si no abres una consulta con tu usuario.
Un saludo y muchas gracias.....
Respondido : 29/04/2021 9:42 am
Reyes
 Reyes
@pepesolerok
Respondido : 29/04/2021 10:12 am
Página 2 / 2
