Evita los redirecci...
Evita los redireccionamientos a páginas de destino - PageSpeed Insights
11 Respuestas
979 Visitas
Respuestas: 87
hola buenos dias, quisiera saber si me pueden colavorar con este tema ya que no se como configurar la sujerencia que me da PageSpeed Insights - me da este mensaje :
asi es el codigo que esta en el archivo htaccess:
# ~~start~~ Do not remove this comment, Prestashop will keep automatically the code outside this comment when .htaccess will be generated again
# .htaccess automaticaly generated by PrestaShop e-commerce open-source solution
# http://www.prestashop.com - http://www.prestashop.com/forums
SetEnv HTTP_MOD_REWRITE On
RewriteEngine on
#Domain: accesoriosrouse.com
RewriteRule . - [E=REWRITEBASE:/]
RewriteRule ^api$ api/ [L]
RewriteRule ^api/(.*)$ %{ENV:REWRITEBASE}webservice/dispatcher.php?url=$1 [QSA,L]
# Images
RewriteRule ^([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$1$2$3.jpg [L]
RewriteRule ^([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$1$2$3$4.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$1$2$3$4$5.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$1$2$3$4$5$6.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$7/$8/$1$2$3$4$5$6$7$8$9$10.jpg [L]
RewriteRule ^c/([0-9]+)(-[.*_a-zA-Z0-9-]*)(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/c/$1$2$3.jpg [L]
RewriteRule ^c/([a-zA-Z_-]+)(-[0-9]+)?/.+.jpg$ %{ENV:REWRITEBASE}img/c/$1$2.jpg [L]
# AlphaImageLoader for IE and fancybox
RewriteRule ^images_ie/?([^/]+).(jpe?g|png|gif)$ js/jquery/plugins/fancybox/images/$1.$2 [L]
# Dispatcher
RewriteCond %{REQUEST_FILENAME} -s [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
RewriteRule ^.*$ %{ENV:REWRITEBASE}index.php [NC,L]
AddType application/vnd.ms-fontobject .eot
AddType font/ttf .ttf
AddType font/otf .otf
AddType application/x-font-woff .woff
Header add Access-Control-Allow-Origin "*"
ExpiresActive On
ExpiresByType image/gif "access plus 1 month"
ExpiresByType image/jpeg "access plus 1 month"
ExpiresByType image/png "access plus 1 month"
ExpiresByType text/css "access plus 1 week"
ExpiresByType text/javascript "access plus 1 week"
ExpiresByType application/javascript "access plus 1 week"
ExpiresByType application/x-javascript "access plus 1 week"
ExpiresByType image/x-icon "access plus 1 year"
ExpiresByType image/svg+xml "access plus 1 year"
ExpiresByType image/vnd.microsoft.icon "access plus 1 year"
ExpiresByType application/font-woff "access plus 1 year"
ExpiresByType application/x-font-woff "access plus 1 year"
ExpiresByType application/vnd.ms-fontobject "access plus 1 year"
ExpiresByType font/opentype "access plus 1 year"
ExpiresByType font/ttf "access plus 1 year"
ExpiresByType font/otf "access plus 1 year"
ExpiresByType application/x-font-ttf "access plus 1 year"
ExpiresByType application/x-font-otf "access plus 1 year"
Header unset Etag
FileETag none
AddOutputFilterByType DEFLATE text/html text/css text/javascript application/javascript application/x-javascript font/ttf application/x-font-ttf font/otf application/x-font-otf font/opentype
#If rewrite mod isn't enabled
ErrorDocument 404 /index.php?controller=404
# ~~end~~ Do not remove this comment, Prestashop will keep automatically the code outside this comment when .htaccess will be generated again
# BEGIN WordPress
# END WordPress
gracias por su tiempo
Respondido : 05/06/2017 5:38 pm
Respuestas: 87
ya se soliciono este error no se como pero ya no aparece
continuando con el mismo tema de velocidad de mi pagina me salen otras sugerencias como
Especificar caché de navegador:
estoy pegando este codigo que encontre en una web en el htaccess
Header set Cache-Control "public"
Header set Expires "Thu, 15 Apr 2020 20:00:00 GMT"
lo pego al final pero sigue apareciendo el error
Respondido : 05/06/2017 10:27 pm
Respuestas: 87
dejo el archivo htaccess como lo tengo ahora
ExpiresActive On
ExpiresByType image/jpg "access plus 1 month"
RewriteEngine on
# Images
# Dispatcher
Header unset Etag
FileETag INode MTime Size
# BEGIN WordPress
RewriteEngine On
RewriteBase /blog/
RewriteRule ^index.php$ - [L]
RewriteRule . /blog/index.php [L]
# END WordPress
y estos son los mensajes
Respondido : 06/06/2017 1:15 am
Respuestas: 87
ExpiresActive On
RewriteEngine on
# Images
# Dispatcher
Header unset Etag
# BEGIN WordPress
RewriteEngine On
RewriteBase /blog/
# END WordPress
Respondido : 06/06/2017 1:19 am
Respuestas: 20131
Verifica si con la sugerencia de código que indicamos en el siguiente hilo el problema se soluciona: https://www.webempresa.com/foro/42-Administraci%C3%B3n-PrestaShop/154536-especificar-cache-del-navegador.html#279079
No es posible que realices varias consulta en un mismo hilo de foro sino que debes realizarlo por separados.
Respondido : 06/06/2017 5:15 am
Respuestas: 87
hola lo tendre en cuenta
de ese articulo me guie para modificar el archivo htaccess pero en page speed siguigue igual
en mobil 50 y en escritorio 60
Respondido : 06/06/2017 5:25 am
Respuestas: 20131
Básicamente lo que te indique es que realices una compresión de los ficheros. En la parte inferior de los resultados puedes descargar los ficheros que te genera el PageSpeed.
Estos ficheros tendrán que ser reemplazados, es recomendable tener el fichero original como respaldo. La ruta de los ficheros la puedes ver en el mismo PageSpeed y el reemplazo lo puedes hacer utilizando el administrador de ficheros de tu cPanel:
Respondido : 06/06/2017 5:38 am
Respuestas: 87
gracias con eso he aumentado 6 puntos en escritorio, mobil sigue en 50 y aun me sale que especifique el cache en el navegador
que mas puedo hacer
el tiempo de respuesta del servidor esta en mas de 2 segundos
Respondido : 06/06/2017 6:01 am
Respuestas: 20131
Para aumentar el tiempo de respuesta puedes cambiar a la versión de PHP 7, tienes una guia en el siguiente enlace: https://guias.webempresa.com/preguntas-frecuentes/cambiar-la-version-php/
Adicional a esto puedes activar Magic Cache pero esto tendrás que solicitarlo enviando un ticket a soporte desde tu área de clientes.
Respondido : 06/06/2017 6:15 am
Respuestas: 87
Gracias y en cuanto a Especificar caché de navegador
no hay mas que hacer ?
si es correcto el codigo del htaccess ?
gracias
Respondido : 06/06/2017 6:31 am
Rafael
Respuestas: 1975
Noble Member Admin
Hola Juan!
Veo que ya lo tienes especificado en el .htaccess que me pasa 🙂
Es correcto el código que has colocado en .htaccess
Te recomiendo tal y como te ha propuesto mi compañero Johnny, actualizar a PHP 7 tu sitio y revisa si es posible activar magic caché en tu web 🙂
Respondido : 06/06/2017 10:07 am
