No puedo cambiar a ...
No puedo cambiar a español add to cart en el homefeatured.tpl
Cristian
 Cristian
Hola estoy trabajando en un borrador con un nuevo tema antes de traspasarlo a mi web alojada en webempresa y tengo el siguiente problema.
He buscado mucho y la solucion que esta posteada aca no me sirve ya que según la solución es cambiar
title="{l s='Add to cart' mod='homefeatured'}" por Añadir al Carro pero mi archivo solo tiene esto y no aparece esa linea
* 2007-2014 PrestaShop
* NOTICE OF LICENSE
* This source file is subject to the Academic Free License (AFL 3.0)
* that is bundled with this package in the file LICENSE.txt.
* It is also available through the world-wide-web at this URL:
* http://opensource.org/licenses/afl-3.0.php
* If you did not receive a copy of the license and are unable to
* obtain it through the world-wide-web, please send an email
* to license@prestashop.com so we can send you a copy immediately.
* DISCLAIMER
* Do not edit or add to this file if you wish to upgrade PrestaShop to newer
* versions in the future. If you wish to customize PrestaShop for your
* needs please refer to http://www.prestashop.com for more information.
* @author PrestaShop SA
* @copyright 2007-2014 PrestaShop SA
* @license http://opensource.org/licenses/afl-3.0.php Academic Free License (AFL 3.0)
* International Registered Trademark & Property of PrestaShop SA
{counter name=active_ul assign=active_ul}
{if isset($products) && $products}
{include file="$tpl_dir./product-list.tpl" class='homefeatured tab-pane' id='homefeatured' active=$active_ul}
{else}
  • {l s='No featured products at this time.' mod='homefeatured'}
{/if}
Respondido : 28/04/2017 7:12 am
Puedes enviarnos un texto de lo que deseas traducir?
He buscado en el foro de PrestaShop y he localizado el siguiente hilo quizás te sea de utilidad: https://www.prestashop.com/forums/topic/349004-solved-change-add-to-cart-button-on-homefeatured/
Respondido : 28/04/2017 8:02 am
Cristian
 Cristian
add to cart por Añadir al carro de la parte frontal del tema, ya que por otros lados aparece correcto y traducido
Respondido : 28/04/2017 8:44 am
Cristian
 Cristian
Ya lo solucione, mi cambio no debía hacerlo en el homefeatured.tpl
lo hice en el featuredproducts.tpl
gracias
Respondido : 28/04/2017 9:30 am
Hola cristian.
Me alegro que lo encontraras :cheer:
Cerramos el tema.
Respondido : 28/04/2017 10:25 am
