Se ha quedado la web en blanco
David
 David
Estamos trabajando en la web y no podemos entrar ni en la web ni en la administración wordpress
Hay un log de errores que es el siguiente:
[22-May-2014 18:59:23 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 19:27:11 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 19:31:37 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 20:01:55 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 20:25:08 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 08:36:12 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 10:57:12 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 11:46:20 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 13:22:16 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
[22-May-2014 19:14:45 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required 'wp-seo-main.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cashcare/public_html/doctor-green.com/wp-content/plugins/wordpress-seo/wp-seo.php on line 41
¿Como soluciono el tema para seguir trabajando?
Respondido : 23/05/2014 5:12 pm
Por el log de errores que comentas parece que hay un error con el plugin de WordPress SEO. Para arreglar esto prueba a ir al directorio wp-content/plugins y renombra el directorio wordpress-seo como wordpress-seo_BAK.
Comprueba si ahora puedes acceder a la administración de WordPress. De ser así, si quieres seguir utilizando el plugin WordPress SEO podrías probar a desinstalarlo y volver a instalarlo.
Respondido : 23/05/2014 6:03 pm
David
 David
Gracias Pablo, ya podemos seguir trabajando
Para volver a activar el plugin worpress SEO, como lo hacemos?
Respondido : 23/05/2014 6:50 pm
HOla David
Debes reinstalarlo, es decir como si no lo tuvieras y lo instalas desde cero.
https://wordpress.org/plugins/wordpress-seo/
Respondido : 23/05/2014 7:35 pm
