PHP Fatal error: Call to undefined method JDate
Tina
 Tina
Hola he estado intentando cambiar de plantilla ya que la que tenia no me acababa de funcionar muy bien , he comprado una nueva plantilla aqui os dejo el enlace exacto
http://bowthemes.com/joomla-templates/bt-ecommerce.htm l">BT E-commerce
He seguido al pie de la letra las instrucciones he incorporado el T3 frame work , los otros modulos etc... y no me aparece nada
La verdad es que despues de cargarlo han empezado a aparecer muchos errores tipo 500 y 503 y despues de enviar algunos tikets me ha indicado estos errores
16-Apr-2013 15:12:01 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:18:17 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:20:21 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:28:04 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:28:19 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:29:50 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:39:52 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:46:34 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 16:02:58 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 16:10:18 UTC] PHP Fatal error: Call to undefined method JDate::toSql() in /home/factoryc/public_html/plugins/system/jat3/jat3/core/joomla/modulehelper.php on line 349
[16-Apr-2013 15:17:35 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
[16-Apr-2013 15:17:45 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
[16-Apr-2013 15:24:03 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
[16-Apr-2013 15:24:33 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
[16-Apr-2013 15:32:05 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
[16-Apr-2013 15:32:26 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
[16-Apr-2013 15:35:53 UTC] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/factoryc/public_html/administrator/components/com_jce/includes/base.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/factoryc/public_html/plugins/editors/jce/jce.php on line 60
Asi como tenia permisos erroneos etc...
Además lo ultimo es que esta web por una parte es una tienda pero por otra visualiza articulos de joomla sencillos y queria añadir un DJ Image Slider ya que necesitaba que fuera responsive como el restom de la web y me lo ha cargado pero cada vez que intento añadir un slide me salta a una pantalla en blanco
Asi que necesito AYUDA URGENTE Ya que sino mañana tendre que restaurar la copia , ya que el cliente no puede quedarse sin web
Respondido : 16/04/2013 7:46 pm
Hola Tina,
Verifica si actualizando el Framework se soluciona el problema:
Actualización importante del Framework T3 de JoomlArt
Respondido : 16/04/2013 11:13 pm
Tina
 Tina
Pues nada la verdad es que ya me havia bajado el ultimo plugin y directamente de la Joomlart y sigue igual asi que no es eso .....
Respondido : 17/04/2013 7:28 am
No conozco la plantilla que indicas ni el club al que pertenece. Dado que se trata de una plantilla de pago te recomiendo que consultes directamente a su servicio de soporte ya que ellos tendrán que estar mucho más familiarizados con el error que se está produciendo.
Respondido : 17/04/2013 9:44 am
